Old 03-04-2017, 02:59 PM   #18 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Egt climbs like crazy at that max boost, like I said it's WOT seems like it hit almost 1200, backing off it quickly goes down to 600 or less crusing at 55-60. Any off throttle deceleration pulls the egt under 200 almost right away. I have the 2004.5 which from what I read will do over 30psi stock.
The torque app reading the MAP shows it is getting boost but it stops registering at I think 22-23 psi and you have to subtract 14 atmospheric pressure. The torque app also shows a boost number but I don't know how it gets that number. It is showing more boost than the gauge. I guess it's possible there is a problem with the new gauge but I also feel it fall flat at 2000 rpm and it does make quite a bit of black smoke at WOT.
