Old 03-07-2017, 07:43 PM   #19 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Well dumb me I had the fuel and boost sending units backwards. One was a 10 bar and I figured that was for boost while the 60 psi was fuel but not according to instructions. I swapped them and I can hit 29 psi boost pretty easy (now the exhaust is open so I don't want to tick off the neighbors) and fuel stays at 10 psi which would be right for a stock in tank lift pump. I also found out that this motor could run 1400 degrees stock so that 1200 isn't crazy. I don't think I will spend much time at max boost so I'm not as worried anymore.
Now the question is if there is a tune. I think I decided to get the Smarty JR. the 2004.5 is write only on the computer so the Smarty has the stock tune inside, plus it has a lower power tune that doesn't add any more fuel, just maps timing better and supposedly lowers cruising EGT a fair amount.
I ordered a muffler and resonator, a 4" air filter, and one new intercooler boot that is missing some expansion preventing rings and feels soft to me.
Feeling much better overall for sure.
The Following User Says Thank You to Hersbird For This Useful Post:
Joggernot (03-08-2017)
