Thread: Ultra Lean
Old 03-08-2017, 12:12 AM   #101 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
Originally Posted by 19bonestock88 View Post
So, if you've disconnected the fuel injectors, you must be starting the engine on some sort of vapor, whether HHO or gasoline... If you built the same 4LPM system that was featured in the video a couple years back of the Saturn, it should provide enough "fuel" to run the Suzuki Carry(660cc, right?), but it still takes more energy to break the water down into its atomic elements, than is made by burning the HHO(and turning it back into water), so you're still somehow at a net loss? You could accomplish it through use of a really big battery to power the hydrogen generator(sort of as a hybrid)...
One question still remains however, you are claiming a 300mpg, with no fuel going to the engine, so on a gallon of what substance are you traveling 300 miles? Water or gasoline?
Basically that silver box has a float valve that keeps the fuel at a set level in the box will that valve you see in the video is his air bypass to control how much air goes through the box, vaporizing the fuel.
The Following User Says Thank You to stovie For This Useful Post:
elhigh (03-13-2017)
