Old 03-08-2017, 06:33 PM   #18 (permalink)
Hoopie
Hoopie
Hoopie's Avatar
December 8th Change of plans.
I didn't like the way the truck was coming together. I sat in the shop and stared at the project thinking it was going to look stupid. Something needed to change. Then with about an hour before I had to leave an idea hit me. Why not do a sub-frame? Years ago I put a firebird sub-frame on a 56 Chevy. It gave me smoother suspension, disk brakes and power steering. I measured the frame rails on the truck frame and on the Prius and they were almost exactly the same. So I grab the saw and cut the front clip off the truck frame and rolled the rear section inside. I cut the Prius just in front of the fuel tank. Using some 4x4s as spacers, I laid the Truck frame on top of the Prius floor. Ratchet strapped them together and set the cab on top. I loved it.
The Following 6 Users Say Thank You to Hoopie For This Useful Post:
AJI (03-26-2017), BamZipPow (03-22-2017), mannydantyla (10-24-2018), MetroMPG (03-09-2017), roflwaffle (03-08-2017), Xist (03-30-2017)
