Originally Posted by Stubby79
Do you need a set voltage, or an adjustable one?
Honestly a set voltage would be fine, but sadly I need to find what it is. (It's between 140-160 volts) the 220vac output variacs seem to be much larger and more expensive than I would prefer..
The 140 volt units seem to not go past 1:1 which makes them useless to me.
Being able to put in either 110vac or 220vac and get around 150 would be nice but not necessary.
Thus far there only seem to be 2 main styles of variac and the ones that boost aren't in those common categories.
Ah well
