Originally Posted by ThermionicScott
150ish volts at 20 amps is a lot of watts! What are you looking to do?
Actually, my source will be a 20 amp outlet the output will use a max of 12 amps.
So I shouldn't exceed 16 amps on the supply side (even with losses)
