Old 03-15-2017, 08:30 AM   #4 (permalink)
DieselJan
Less waste = better FE
Originally Posted by jakobnev View Post
I think the biggest flaw in this design is, that a normal rigid conrod, doesn't cause the problems You think it does.
Hi Jakobnev
I know the conrod doesn't cause the problems, but I think it can solve the problems. The problems is caused in the combustion chamber above piston. The problem is caused by sudden combustion causing an impulse, this impulse is the sudden high pressures and temperatures. The conrod mod is to smooth the impulse and convert it into useful work.
See an example here
The resulting waveform with the modification will probably look something like the attached scan. The area of the graph above the spring pressure will be delayed and added where it is more useful to generate output work. Remember that all the pressure and heat at TDC does nothing for usefull work, it only heats combustion chamber walls and cooling fluid. The real work is only transferred to the wheels after TDC.
Last edited by DieselJan; 03-15-2017 at 08:37 AM.. Reason: Spelling and adding some info.
