Old 03-15-2017, 12:40 PM   #7 (permalink)
cRiPpLe_rOoStEr
I would also fear it to actually increase the pumping losses.
Originally Posted by DieselJan View Post
The spring will generate very little heat. The energy it absorbs will be converted back to pressure as soon as combustion pressure goes below spring pressure.
Even though the heat generated would eventually be almost negligible, it's still not going to be converted back into "pressure", neither control so effectively to which direction it would be applied.
