Old 03-17-2017, 12:34 PM   #30 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Magnets:they really do not like heat...
That amount of force, your springs are roughly the size of the springs in your suspension.
Also, when you fondle a spring, it goes wobbly wobbly, that could be deteimental in an engine that has variable rpms. You should look at tuning mass spring damper systems (if you have friends that are good in electronics, it is the same as RLC {capacitance, inductance and resistance} circuits).
Also at those speeds and forces I doubt that your spring will be linear (which may or may not be to your advantage).
