Old 03-19-2017, 06:44 AM   #20 (permalink)
oil pan 4
I think the trick is water injection actually doesn't do anything at all when you are trying to get increased fuel economy.
A dangerous mix of high compression, regular gas and lean burn for economy.
Then water or water and methanol injection to tame air fuel detonation under high load, so you don't have to burn aviation gas all the time, which is expensive and not economic at all.
Assembly line made gasoline engines are designed to be mild enough to not benefit from water injection. So power and possibly fuel economy suffer.
