Thread: Eco My Echo
Old 03-19-2017, 11:07 PM   #4 (permalink)
puddleglum
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Thanks. Yes, bigger engines make more heat. Ambient temp and longer trips make a big difference too. My regular commute is 4 miles. Around freezing its up to temp in a couple of miles and I usually turn the heater on then. When it was -15/-20F, I had to turn on the heater after the first mile or two but it never got quite warm enough to open the thermostat. Shorter commutes with the family were worse since I needed the heater on right away. Its's good around town as is to about 50F but warmer than that and I will need to open things up some. Insulating the coolant hoses might be worth a try. I wish I had a garage for winter. The wheel bearings get so stiff in the cold it feels like the brakes are dragging.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
The Following User Says Thank You to puddleglum For This Useful Post:
101Volts (06-05-2017)
