Old 03-20-2017, 01:16 PM   #15 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
I wonder also if i can really wrap a lot of copper pipe around the exhaust manifold so that i can inject less steam at high temperature.
I also intend on using 0.5 mm ID 1.5mm OD silicone tubing to transfer the steam. The restriction will increase slightly the pressure of the system and provide fast flow on the output enabling proper mixing.
I still have to look at the delay of the system an maybe implement a smith predictor or such algorithm.
