probably because I know the distributor works very reliably and likely is a very, very small load on the engine. As for the Alternator, I'll remove the belt and solar charge. Seems like a lot of work to go the stator route and to figure out how to make it work as effectively as the distributor. But... I like your thinking outside the box!
