Old 03-21-2017, 11:08 PM   #28 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by teoman View Post
- I have a copper pipe wrapped around the exhaust which heats up.
- I have an injector on one side, the injector is never heated and it has a heat-break (silicone tubing) to prevent that.
- The other side of the copper pipe is connected to the intake by hose (after MAF).
The injector shoots the water out which arrives at the pipe. As it evaporates, it expands. But it cannot escape by the route which it came from, it is blocked by the injector. So the only way to go is travel the copper pipe, then the hose in to the manifold.
My objective going this route, is to be able to control the intake air temperature precisely, keep it at an exact temperature range, instead of relying on it to suck up some unknown air temperature near the exhaust manifold.
You're going to want to force some airflow through your copper pipe, or it will quickly fill up with hot water, and you won't get your desired steam output. A good amount of insulation on that pipe is also called for.
The Following User Says Thank You to t vago For This Useful Post:
Xist (03-30-2017)
