Old 03-22-2017, 11:50 AM   #8 (permalink)
oil pan 4
The trailer brake coils ohm out at 4 ohms each.
That is likely too high to series and be effective.
I will wire everything back to a terminal box so all I have to do is switch a few wires if it doesn't work.
Still waiting on the machine shop to get to my axle. They are going to press fit the spindles into the axle.
When I get a lathe and milling machine it won't be to save money, I can afford the machine work, the waiting is the hardest part. It will be done to save time.
