Old 03-24-2017, 07:28 PM   #28 (permalink)
HaroldinCR
In my experience, if a V belt starts to slip, you COULD burn it just a tad thinner in that one spot and it would only get worse from then on.
I'm planning the cog "timing" type belt on my reverse trike. I have 2 hills that I need to get a run at and 1 is dirt/rocks just below our house. Check ebay for belts. I bought a used Can Am Spyder rear pulley and will get a couple different sizes for the motor shaft.
The Following User Says Thank You to HaroldinCR For This Useful Post:
thingstodo (03-24-2017)
