Old 08-16-2008, 12:33 AM   #222 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Alright
As far as the brake lights go.
There is a switch on your master pressure switch (may be located on a "T" on later bugs)
Basically the switch should close when the pedal is pressed; if it does not the switch is bad. if it does make certain that there is 12 volts getting to one side; them make sure that when you apply 12 volts to the other the brake lights illuminate. it isn't a complicated circuit (now the turn signals are still a mystery to me) .
6 speed ALH TDI
