curious
Originally Posted by gumby79
That ^^^is sexy...
I like the tail section of the green house how it blinds into the flat deck. Looks like the air wants to follow ... I'm curious if the rear would have lift or downforce[edit: without the wing]? Looks like downforce with that up turn at the end.
The tail is similar to the bottom configuration in the table below,with lowest drag,although the lowest lift is with the middle configuration.
Reason: correct comment
