Old 04-03-2017, 01:00 PM   #8 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Here is a list of mods and maintenance that I have planned.
Maintenance
- Drain and refill the MT with Honda recommended fluid
- Clean headlights
- Fix small oil leak from the top part of the motor, can't remember the name of the part
- Clean EGR
- P0420 and P1449 codes
- Get IMA system back up and running
- Fix the driver front interior fender well
- OEM engine bay belly panels?
- Replace broken door handle and repair driver's door (pics later)
Aesthetics/pleasure
- Reinstall CD player
- Upgrade speakers
- 8" subwoofer w/ amp
- New paint job, OEM red, MAYBE Citrus
- Interior restoration
Planned Eco-mods
- Grill block
- Remove rear wiper
- Remove POS factory antenna
- Custom front belly pan if OEM leaves something to be desired
- Custom rear belly pan at appropriate angle to reduce lift
- 14x4 Insight space saver rims w/ new RE92's @ 80 psi
- Boat tail
- MIMA
- Warm air intake
- Engine kill switch for EOC
Eco-mods implemented as of 4/3/17
- Tire pressure of 60f/55r
- Driving by FCD
- Neutral coasting as much as possible!
If y'all remember my Escort build, it was MAJORLY function over form. I want this build to be a delicate balance of form and function, to make it look like the Insight came from Honda with full Ecomodder glory.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following 2 Users Say Thank You to BabyDiesel For This Useful Post:
Daox (04-03-2017), Ecky (04-03-2017)
