Old 04-04-2017, 12:19 PM   #1 (permalink)
Keller
speed demon
Keller's Avatar
Single passenger chop top metro build
This will be a long process I'm sure. But I wanted to show off a little of my work.
My goal is 80mpg@80mph.
I am not an economic driver at all. I drive over 120 miles a day all highway and all fast paced.
It takes me long enough to get to work so trying to hypermile and drive 65 ain't happening for me.
But what I can do is put my fav skills to work to create a car, built specifically for my needs that should drastically reduce the overall drag.
My envision started when I first saw the Elio. I knew from the get go it was all a scam based on the sales pitch, but it got my wheels spinning About how I could build it myself.
Which led me here. Where I have been reading and learning for years. And through that learned the faults of the Elio in the front suspension, grill area and just everything really.
I always liked Doug Heffrons car. But through this web site I also learned it was much lacking in possible modifications. To further his milage.
Going in to my build knowing I have to make the car get the milage and not my foot has controlled my thoughts for a long time. And I am finally getting the chance to work on my vision.
I don't have any fancy drawings except for what's in my head. But the build will consist of.
#1 A total grill block with no openings or cracks whatsoever. Plus 98 led headlights
#2 Full wheel covers up front and back.
#3 Doug Heffron style single seater with 8" chopped out of the roof line.
Laid back windshield.
#4 Boat tail starting from right behind the driver's head
#5 Passenger door still functional as a trunk for lunch box ECT...
#6 Extended rear deck to match up with boat tail coming from roof.
#7 Rear grill opening were the radiator/condenser combo will be hiding.
#8 Passenger firewall will be cut out allowing the trapped air from front wheel wells to be re used as cooling air then reintroduced back to atmosphere at the tailing edge.
#9 and possibly lowering it as far as it will go with the help of some air shocks to get me in and out of job sites.
96 dodge neon dohc 5speed. 33mpg
95 metro 3cly 5speed 45mpg
120 mile round trip to work. No I can't move closer :-(
The Following 3 Users Say Thank You to Keller For This Useful Post:
BamZipPow (04-06-2017), MetroMPG (04-04-2017), RedDevil (04-05-2017)
