No linky, but I did some research and it appears tire weighs about the same as aluminum and less than steel. So the wheel diameter shouldn't matter with aluminum.
On my car with 26" tire diameter and 2000lb weight, the perfect tire would be the 165-50/19 Bridgestone Ecopias from the BMW i3. They are unique and probably undersized for your Camry.
