Old 04-08-2017, 10:47 AM   #7 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by Wiegraf View Post
Shortie.. going on different car now but yes it will have a vacuum.and AFR gauge.
Awesome! As far as the grill block goes the best pics I had of it are post #38 and then I explained how I fixed an issue with it sagging on post #41. I have had to take it off because of cooling issues (note: not caused by the grill block) and it got left behind when I moved. If I remember correctly what I did as a quick and easy way to adjust the weight was insert a bolt through one of the fins near the back edge and I could add nuts to it to add weight. I think before I went that route I just taped sections of rod to the bottom of a fin near the back edge.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
