Old 04-11-2017, 12:43 AM   #1 (permalink)
sameb
Rogue Engineer
cam and crank sensors wanted
I have a 2001 Civic DX. I'm trying to advance the timing by using a piggy back computer I'm making with an Arduino Due. The Due will read the crank and cam signals and effectively advance the base timing, then the ECU will apply its maps. I'm trying to get more mpg out of E85.
To make a nice connection I need to cut up one each of the cam and crank position sensors. I just need the connector so if you have some non-functional ones laying in your shop let me know. I'm going to use these for the female connection
Honda misc sensor, ignition coil, tdc, crank, knock, map connector pigtail acura | eBay
