Please don't reference my 3D model in post #2.
????? Perhaps you should delete it? All I did was point to the Permalink. All we have to go on is what you post. If it's any consolation, my 3D models 'never get the refinement they deserve' as well.
Why did you pick that one detail out of the post to respond to? Overall it was about the mathematical tools to lay out the full scale patterns.
https://en.wikipedia.org/wiki/Honda_Insight
I can see that; the lower body is somewhat boxy. Are you going to use an Insight's glass or hatch?
You're changing from a convex curve to a reflex curve, are you just going to lift dimensions off an actual Insight? Compare the section through the Insight A-pillar and your B- or C- pillar.
