Old 08-16-2008, 04:26 PM   #6 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
trikkonceptz,get to Darin's thread for his permanent Kammback on the Metro.We created an aerodynamic template for everyone to use as a go-no-go- for streamlining.If you photo-enlarge or reduce a picture of your candidate tractor,then slip it under the template,it will show you the "curvature" you'll need for a fool-proof tail.It's not really about angles as it is curves.Without the initial curvature you'll have separation.You can also use the template to design the sidewalls as well.Pull this one off and T.Boone Pickens will be knocking on your door for cash! Good luck!
What's sad is I was researching this to see if I am re-inventing the wheel here and all I found was a company that got money to build what they called a boat tail ... Try not to cry to hard; Ken Visser Research Page
The sad news is they saw a positive change with something so primitive. But in my opinion is so wrong on so many levels.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
