Old 04-17-2017, 05:57 AM   #4 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Everything that I can find shows the Tercel having a standard Toyota EFI system that has a manifold referenced fuel pressure regulator with a return line. In the post above, you can see the return line and manifold pressure line. On the hidden side, as a part of the flange, is an o ring connection to the fuel rail.
In my >30 years of owning and working on Toyotas, I have never seen or heard of a mechanical in-tank fuel pump.
Simon
