I'd say, definitely do a full belly pan, front lip, WAI, max sidewall pressure and EOC kill switch. Also install an MPGuino, it dramatically helped me improve my driving habits. I do synthetic fluids too, not sure if they help or not, but worth a shot. Another thing you could consider is removing your power steering (if it has it) and switching to manual or if you must have power steering you could switch to electric by using the parts from an MR2. That's what I'll be doing, eventually.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
