Originally Posted by Shortie771
I'd say, definitely do a full belly pan, front lip, WAI, max sidewall pressure and EOC kill switch. Also install an MPGuino, it dramatically helped me improve my driving habits. I do synthetic fluids too, not sure if they help or not, but worth a shot. Another thing you could consider is removing your power steering (if it has it) and switching to manual or if you must have power steering you could switch to electric by using the parts from an MR2. That's what I'll be doing, eventually.
All my civic that had PS were "converted " to manual.
MPGuino is a must. (Where should I order from)
Mpguino.wiseman.ee ?
And what's the setup and technique behind the EOC kill switch?
It will get full synthetic fluid (Probably Castrol) and I usually use Synchromesh in all my manual transmission cars (including my JDM LSD trans for my honda). Occasionally on a built trans I use Red Line lightweight synthetic too...wonder where those stand on FE
