Old 04-20-2017, 08:04 AM   #26 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
The rpm at 60 is about 1800 in 6th and 2200 in 5th if I remember right. The EGT is just before the turbo. It will go much higher than 1100 and will boost up to 31-32 psi where the waste gate opens and puts it about 29 psi. The EGTs then go over 1400. I try to stay away from that kind of boost and temp instead letting it lose some speed and just slow down some on the really steep passes.
