Old 04-24-2017, 11:16 AM   #1 (permalink)
jackbauer
jackbauer's Avatar
EV CAN Battery Monitor
Here is a little project I'm working on. I cannot find a nice robust battery monitor so decided to have a go at my own. Sensor board is based on an Atmega328 and an ADS1115 16 bit ADC in differential mode. Reads voltage from 0-500v and current from -600 to +600A and temperature via a thermistor. Transmits via CAN and bluetooth.
All files on my github:
https://github.com/damienmaguire/EV-CAN-BAttery-Monitor
Software is only bare bones with no checking for valid CAN IDs etc but it does work. Struggling a bit with the amp hour calculations.
Name:	2017-04-24 11.47.53.jpg
ID:	21614   Click image for larger version
Name:	2017-04-23 16.21.22.jpg
ID:	21615   Click image for larger version
Name:	2017-04-23 16.21.16.jpg
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 3 Users Say Thank You to jackbauer For This Useful Post:
HaroldinCR (04-27-2017), Stubby79 (04-24-2017), thingstodo (04-24-2017)
