Old 04-24-2017, 11:37 AM   #21 (permalink)
alexander.foti
Originally Posted by teoman View Post
I am examining my torque app values, and at idle, if i have the engine in gear (automatic transmission) then FC is 44 cc/min but if I switch to neutral it becomes 38 cc/min. I can coast in neutral, but if i were to completely shut off the injectors, that would amount to quite some savings.
Yes you are correct, you could realise some savings, however, the autobox does not like to be moved around in neutral with the engine off for long periods of time.
MB recommend disconnected the prop shafts if longer than 20 miles or so towing with the wheels on the ground.
You could probably get 2-8% fuel savings turning the engine off/on and lights though, depending on your journey type.
