Hi, I wonder if someone would be kind enough to clarify something for me. I'm no installer and I'm having trouble keeping this how-to clear enough to start the project. Even a napkin schematic would help. Anyway, the two major points I'm stumbling on is 1) What is meant by "jumper from 30"? If I'm already getting power from fuse block, it leaves no room for a jumper wire. And 2) Do I need a three pin switch or just two... and does it need to be rated at 30 amps or will a small one do since there's a relay? Thanks very much for the write up— I'm sure for the electrically inclined, it's all that's needed but for the "special" among us, a bit of clarification might help.
