Old 04-25-2017, 06:40 AM   #17 (permalink)
foot to the floor
Cool
Originally Posted by California98Civic View Post
The VX wheel is generally listed at 9.7lbs and the 1996-2000 HX wheel at about 11lbs.
Here's my list from my car's garage page... there are links to further info on the page itself, under planned mods...
Possible wheel swaps for gearing/weight advantages:
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11 lbs)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)*
15" Kosei K4R (10.7 lb)*
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm*
15" Acura Integra GSR (94-95, 16lbs)
Other size specs to double-check for any possible swap: Offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum (larger needs spacer rings). For more info see 1, 2, and 3 (for general wheel size data across models).
14" Enkei RP-F1 (8.4 lbs)*
14" Kosei K1-TS (9.3 lbs)*
