Old 04-27-2017, 04:22 AM   #2 (permalink)
freebeard
Higher average speed = taller gearing. The ROI to change overalll ratio is in changing the tire size. What do you have currently? You can probably go narrower on the same rim, but eventually, like the BMW i3, you go to a bigger wheel diameter to go taller and narrower.
GMC Acadia Forum: The black metal bar under the vehicle
Is it this shiny?
