Thread
Creepy White Van - E150 aerodynamics
04-27-2017, 10:03 AM
6
permalink
Merlyn2220
Deep Lurker
Creepy Van
- '95 Ford E150 Cargo
90 day:
14.45
mpg (US)
At some point I will go back and remove the driver's side axle-axle bellypan, and run a full tank of gas without it. It's not too difficult to remove, since it is held on by rivnuts. I've just been working on other parts and haven't gotten around to trying it. The next thing that I did was build a really poorly designed rear shell/taper...with NO TAPER!!! I had a bit of taper to the side, but the spray foam bulged it out, and because I built the top first, I didn't have any vertical taper...especially at the edges! So learn from these pictures and DON"T DO THIS! It took 4 days of work to make this mess:
Merlyn2220
View Public Profile
Send a private message to Merlyn2220
Find More Posts by Merlyn2220
