Old 04-28-2017, 03:03 PM   #106 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by skybolt View Post
Adafruit shield working great, at least with debug readings. LCD init isn't an issue if LCD is powered from 7805, which works well. Warning: Do NOT use 12v input for Arduino Pro Mini 3.3v (even though the onboard voltage regulator clearly states 12v is acceptable). Fried many boards (regulator KB33).
Cannot compile 20170210 code, with #define useDebugReadings true enabled and #define useAdafruitRGBLCDmodule true enabled. (Your lines may vary as I added some LED blinking code to the JSON function so I could tell when the Arduino was active). Tried disabling #define useBufferedLCD true and #define useTWILCD true (in both locations including the define embedded in ifdef Adafruit ...).
I believe it's tied to your DevLCD code, which appears to be a placeholder for LCD code under development (like Adafruit!)
I just downloaded and attempted to compile the 20170210 code, with useDebugReadings and useAdafruitRGBLCDmodule enabled. It compiled successfully.
Can you upload here what you have?
