Old 04-30-2017, 01:36 AM   #4 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
They're basically "cold weather" lifepo4's.
You can't charge a LiFePO4 below freezing, or you'll "plate" the anode or cathode and loose 20% of your capacity, IIRC. These have a Mn plating on them to prevent that, from what I read. However it works, it allows you to charge/use them down to -20c. You'll see that in the specifications on that web page you listed.
If you want to do winter driving without using a battery warmer, these are the way to go. They're notably heavier, mind you. 20% or so, for the same capacity. If it almost never gets below freezing, there's not much point to spending the extra or carrying the extra weight.
The can take a slightly higher end-charge voltage, otherwise they operate the same as LifePO4. 3.8v instead of 3.65v.
(I looked in to these when someone was selling a used set locally, but they were too damned BIG for my use. And he was asking too much for them).
PS: take this with a grain of salt, as I'm pulling this info out of 3-month old memories and not checking my facts.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
California98Civic (04-30-2017), thingstodo (04-30-2017)
