Thread: Warm air intake
Old 05-02-2017, 07:43 AM   #79 (permalink)
oil pan 4
Originally Posted by Magician View Post
Why do you think it can't put out an amp? According to the manufacturer, it does. And... if you take 13w/12v = 1.083 amps... in dierect sunlight that is. Do you own this panel and have you tested it? Just curious... I'll let you know. I'm sure the controller will drop it a bit.
Because I found when you put a layer of auto glass in between the panel and the sun it can cut the panel output by 1/3 and not having the panel perpendicular to the sun can cut panel output by half.
There is no way that panel is making an amp.
I put solar panels in and on vehicles and I have amp meters.
I use a fluke325 amp clamp meter.
