Originally Posted by drivenByNothing
iduino and radioshack 4x2x1 case. Not perfect, but as close as I need it to be.
This required a lot of cutting not only to the enclosure, but I also had to cut the LCD board's corners off to get it to slide between the parts inside the enclosure that accept the screws. The rear terminals are for +12v, ground, VSS, Injector.
4x2x1, huh? I assume you're using the iDuino for your
MPGuino (that and the 7805 sticking out the rear). Can you take some pics of the boards themselves inside the case? I just built my iDuino and was about to start on the rest of the board, and would love to see how you set up your board to get it to fit in the case. Thanks!
