Old 05-04-2017, 07:30 PM   #64 (permalink)
grabowski
Going mechanical will be simple to do with all the right parts and as you are going in with the manual, that will help. My neighbor has a '94C2500 that must have 3.7x gearing, with the auto and she says on the highway, 65mph with cruise control on she sees 23mpg. I have heard rumors of manual tranny 3.4x geared C2500 getting 25-27mpg.
The frontal area of the 2wd is much lower to the ground and a bit of less weight vs the 4wd chassis. With the factory air dam, my mpg did go up.
Why put the heavier and wider 255 tires compared to the 235s?
The Following User Says Thank You to grabowski For This Useful Post:
aardvarcus (05-08-2017)
