Old 05-07-2017, 10:40 PM   #4 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
In addition to the lower axle ratio, while you're in there consider changing the differential to a limited slip model. I think your winters in the Netherlands get a lot more snow than Texas ever did, and the LSD will help keep you on the road and mobile.
With a lower axle ratio you might want to consider a new camshaft to move the torque peak further down the Rev range to complement the lower cruising revs.
Really interesting project.
