Old 08-17-2008, 06:35 PM   #501 (permalink)
drivenByNothing
Not a problem, but just so I'm not taking up space on the page, here's a link to the directory.
Index of /images/duino
There's still some stuff that could potentially be trimmed to save room, but I think I've invested enough time already. I have my reasons for letting the components stick out the back of the enclosure. The 7805 does get a bit hot, so cooling is a concern. The terminals are sticking out because it makes it very easy to access the screws for the wire clamps. Space was also getting tight and I wanted everything to fit comfortably. The terminal blocks would easily be replaced with another type of connector and the 7805 could definitely fit inside of the enclosure w/o a problem (well, the heat would still be a concern).
