Old 05-11-2017, 03:45 AM   #18 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Finally a real update! I took the car out for a spin today and WOW! The new clutch is better than any stock clutch I have ever felt. Also the new injectors are working great. My fuel trims are +/-5% (this is Normal).
So pros/cons of the Spec clutch.
Pro's:
Lighter peddle pressure than stock.
No bouncing if you drop the clutch too fast.
Will hold about 50% more power than stock.
It's blue.
Cons:
It's twice as expensive as a stock clutch (I paid 401$ for mine)
It's less forgiving.
[What do I mean by, 'less forgiving'] Well it means when it grabs, it grabs, you can't really 'slip' it to help you get going. The overall pedal travel is nice, and I had mine running on gas only (clutch switch enabled) so yea. If I had the electric motor enabled it would have probably been fine, but unlike the stock clutch, a gas only Insight doesn't make enough power down low to slip the clutch.
