Old 05-11-2017, 11:24 AM   #32 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
Stuck in traffic shouldn't be a problem.
When using AC, the cooling fan defaults to always-on mode. There should be plenty of airflow even while stuck in a stack of traffic. Cleaner coils will help you tremendously.
That said, stuck in traffic with a bunch of other engines all dumping heat into the air is when you would want the misting system the most.
