They make a "lower profile" version of the flat-kit that silverdwings showed (they kinda look like screwdrivers), I keep one in the glove box, just in case.
And if you're having trouble spotting a slow leak, put a little dish soap into a bottle of water and spray/splash it over your leaking tire.
Find the spot where the bubbles are spewing forth and you've found your leak.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
