Old 05-12-2017, 03:42 PM   #121 (permalink)
josemapiro
Hi t vago
The problem of waking up that I had before, with this change did not happen again.
But I encountered a problem while scrolling through the setings, when it was. "Scratchpad (odo?)" It does not proceed as it should, it goes to the definition of this parameter, the same happens when I run in the opposite direction, When it is used, the "P(Fuel) Pa" it goes to the definition of this parameter.
Also the name of the parameter in some situations does not erase the name of the previous parameter being visible in the following as you can see in the video.
A correction that should also be made was with the "AutoSave" that should only save when you make a new trip and not only because you pressed the button, also the message that shows "AutoSave Done" should disappear after 1 or 2 seconds, And display again the screen that was before the autosave.
https://youtu.be/KcBTZwrR4QA
https://youtu.be/M9AfyjfGD4g
Thanks
José Rodrigues
