Old 05-14-2017, 12:32 PM   #27 (permalink)
freebeard
If the sharp edges are bad. Then after a front bubble, could you simply take pvc pipe and slit down the length and glue that over the long side sharp edges to round them?
A single slit would produce a raising, 3/4-round edge. Two slits and butting the halves would produce a half-round. Then it's down to the 4%-of-gross-width rule, generally ~4".
ksa8907 — Closing the gap is non-trivial.
