Old 05-16-2017, 06:16 AM   #43 (permalink)
Jack-Lee
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Hi,
now the engine is almost finished (only the aircleanerbox is not in place)
I lathe the valves so i cut it about 2mm (i musst lathe a new notch for the cones). The reason : I would use light 50g hydraulic valve lifter from a BWM. These dont push my valves "half open" when the oil pressure rise above 2bar.
After that i weld the new intake Manifold. 0,82l Plenum, 190mm tube-length, 28mm tube-diameter, 150mm throttlebodylength,58mm throttle diameter.
I worked until 7am.. (about 20h without a break )
And now : The engine is like it should. Diesel-like but gasoline driven.
(PS. the performance-chart was driven with AFR 16,2 !)
ID:	21773   Click image for larger version
ID:	21774   Click image for larger version
ID:	21775   Click image for larger version
ID:	21776   Click image for larger version
The Following User Says Thank You to Jack-Lee For This Useful Post:
Logic (10-01-2022)
