Old 08-18-2008, 12:13 AM   #225 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I found a useless (hopefully) wire that led to the engine compartment that became 12v once the key was turned the whole way, so I can use it for the on/off switch for the contactor. I don't know an easy way to turn on the pre-charge resistor using the middle setting of the key turning process. I guess I could use an SCR, that has a gate that can be open at around 12 volts, and the other part has to be like 72 volts. That's stupid, but it could work. I have a huge SCR, but this is stupid. I could just push the dang button how it is.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
