I have quite stupid question. Steel frame you can cut to parts and melt with other scrap metal to make steel again. How do you recycle wooden/plywood/wood composite frame, that is probably infused with ton of epoxy resin to add protection against elements?
So is the wooden frame just a pose, or does it have benefits I do not see?
